*writemodelcheckresultfile
Writes out model check results to a file.
*writemodelcheckresultfile filename filetype
HyperMesh Tcl Modify Command
filename
The full path and name of the file to write. By default it will be given a .txt extention if not specified.
filetype
0 or 1 - Only the failed count associated with the checks is written out
2 - Entity type, failed count and count of entities in the model are written against the check
3 - Along with the above information, the time taken to run each check is also written out
4 - A detailed CSV report with entity type, run status, failed count, comments and failed entity IDs against each check is generated
5 - Writes out failed count against only failed checks flagged under user status column
Examples
To write results to the file C:/temp/check_results.txt
*writemodelcheckresultfile C:/temp/check_resutls.txt 1
   # Handle error
Version History
2019
