*morphdoshape
Apply undo, redo, undo all, or redo all.
*morphdoshape option
HyperMesh Tcl Modify Command
option
1 - Undo most recent morph
2 - Redo most recent morph undone
3 - Undo all morphs
4 - Redo all morphs
*morphdoshape (2)
"Morphs" are applied sequentially to the model and stored in a stack. You can move through the stack using the various undo and redo commands to morph and unmorph the model.
None.
