*morphhyperpreviewbezier
Draws vectors for shapes to be created using morphbeziershape if a shape is being used.
*morphhyperpreviewbezier dtype dmark shape
HyperMesh Tcl Modify Command
dtype
Domains
dmark
Domain mark number
shape
ID of shape
A vector is drawn for each handle on the mark according to the shape. This is used to preview the shapes that will be created in the autoshape panel before creating them. If symmetry is used, all handles linked to marked handles by symmetry will also be perturbed. If constraints are used, they will be applied to the perturbations.
*morphhyperpreviewbezier (DOMAINS,1,12)
None.
