*elementtestrigidloops
Tests 1D rigid elements for possible rigid loops, and puts those with rigid loops on the specified outputmark.
*elementtestrigidloops entities markmask outputmark
HyperMesh Tcl Modify Command
entities
The entity types to be checked. Currently, only elements is supported.
markmask
The mark that contains the elements to test.
outputmark
The mark where HyperMesh should put the elements that fail the test.
*createmark(elements,1) "displayed"
*createmark(elements,2)
*elementtestrigidloops(elements,1,2)
