*smoothelements
In the automeshing module, applies the specified smoothing operator to the mesh (if any) found on the face for the given number of times.
*smoothelements faceindex smoothmethod iterations
HyperMesh Tcl Modify Command
faceindex
The index of the face into the particular surface under consideration.
smoothmethod
The smoothing method to use.
  • 0 autodecide
  • 1 size corrected
  • 2 shape corrected
iterations
The number of times to apply the element smoothing operator.
To smooth the elements of the mesh of the first face of the surface twenty-five times, using whichever algorithm the automeshing module determines is proper:
*smoothelements(0,0,25)
The undo function for this command is *unsmoothelements() .
None.
