*nodecreateatlineparams
Create nodes or points at parametric locations on a line.
*nodecreateatlineparams line_id double_array number_of_doubles insert_count mode point_flag
HyperMesh Tcl Modify Command
This command creates nodes or points at points on given line for given parametric values.
line_id
Input line ID.
double_array
The ID of the double array that contains the parametric location values in the range 0 to 1. The double array is created using the *createdoublearray command. This should always be set to 1.
number_of_doubles
Integer indicating the size (number of doubles) in the double array created using *createdoublearray.
insert_count
Number of additional parametric values inserted between the values specified by the array in double_array.
mode
Specifies how parameters specified in double_array are used. Valid values are:
0 - Line arc length parameterization is used.
1 - Internal line parameterization is used.
point_flag
Parameter specifying whether nodes or points are created. Valid values are:
0 - Create nodes (default)
1 - Create points
Examples
To create nodes on line 12 at arc length parametric values 0.2, 0.8 and 0.85:
*createdoublearray 3 0.2 0.8 0.85
*nodecreateatlineparams 12 1 3
To create 10 points on line 12 using the line’s internal parameterization with parameters equally distributed between 0 and 1:
*createdoublearray 2 0 1
*nodecreateatlineparams 12 1 2 8 1 1
   # Handle error
Version History
10.0
