*usercheck
Runs a template that can be used to check element quality
*usercheck template file output file all
HyperMesh Tcl Modify Command
template file
The name of the template file.
output file
The name of the output file.
all
Determines the entities the template scans.
1 - Specifies all entities.
0 - Specifies only visible entities.
The template file can use the *markfailed() template command to mark elements that do not pass any user-specified test. *markfailed() highlights the element on the screen and also puts the element on the user mark.
None.
