*createcirclefrompoints
Creates a circle or arc from 3 nodes.
*createcirclefrompoints list_id circle_flag
HyperMesh Tcl Modify Command
This command creates a circle or arc from 3 nodes.
list_id
The ID of the list containing the nodes that define the circle. The order of the nodes is important if creating an arc.
cirlce_flag
1 - Create a circle.
2 - Create an arc.
Examples
To create a circle through nodes 100, 200 and 300:
*createlist nodes 1 100 200 300
*createcirclefrompoints 1 1
   # Handle error
