*createentitiesfromsource
Creates entities using an external source file.
*createentitiesfromsource <option1>=<value1> <option2>=<value2> ... <optionN>=<valueN>
HyperMesh Tcl Modify Command
entitytype=<value>
The type of entity to create. Currently only supported for beamsects.
source=<file>
The path and file name to the source file.
Examples
Create beam sections using a csv file:
*createentitiesfromsource entitytype=beamsects source=C:/temp/beam_section.csv
   # Handle error
Version History
2019
