*replacentitywithentity
Replaces a single component.
*replacentitywithentity mode entity_type existing_id incoming_id string_array number_of_strings
HyperMesh Tcl Modify Command
This command replaces a single component.
mode
The replace mode. Valid values are:
  • 0 - Undo/reject replace operation.
  • 1 - Initial replace operation.
  • 2 - Finish/accept replace operation.
entity_type
The type of entity to replace. Currently only supported for comps.
existing_id
The ID of the existing/old entity.
incoming_id
The ID of the incoming/new entity.
string_array
The ID of the string array that contains the input options. The string array is created using the *createstringarray command. This should always be set to 1.
The supported options and values are:
tolerance=value
The replacement tolerance. Right now it is a global tolerance, meaning the same tolerance is applied for all replace entities. The default is 0.01.
keep_src_prop=value
0 - Do not reuse/keep the property assigned to the outgoing component (default)
1 - Reuse/ assign property of source component to the outgoing component.
keep_src_mat=value
0 - Do not reuse/keep the material assigned to the outgoing component (default)
1 - Reuse/assign material of source component to the outgoing component.
keep_src_comp_cardimage=value
0 - Do not reuse/keep the card image assigned to the outgoing component (default)
1 - Reuse/ assign source component card image to the outgoing component.
keep_src_include=value
0 - Do not organize the incoming component to the outgoing component include (default)
1 - Organize the incoming component and its nodes/elements/reference entities to the outgoing component include.
log_file=value
If a log file is desired, value should be set to the full path and file name to write to.
number_of_strings
Integer indicating the size (number of strings) in the string array created using *createstringarray.
To replace component 301 with component 501 using a tolerance of 0.5, keeping the source material, property and card image:
*createmark comps 1 100
*replacesetentitydata componentmark=1 componentpairingstring={{301 501}}
*createstringarray 4 "tolerance=0.5" "keep_src_prop=1" "keep_src_mat=1" "keep_src_comp_cardimage=1"
*replacentitywithentity 1 comps 301 501 1 4
   # Handle error
Version History
13.0
2017.2 - This command used to work independently, but must now be preceded by a call to *replacesetentitydata.
