*setparameter
Parameterizes a data name or attribute on a single entity.
*setparameter name entity_type entity_id data_name_or_attribute row column reserved
HyperMesh Tcl Modify Command
name
The name of parameter entity to assign.
entity_type
The type of entity to parameterize.
entity_id
The ID of the entity to parameterize.
The data name or attribute name/ID to parameterize.
row
The row index of the attribute in a 1D or 2D array. Must be set to 0 otherwise.
column
The column index of the attribute in a 2D array attribute. Must be set to 0 otherwise.
reserved
Must be set to 0.
To parameterize attribute LSD_DA1 on entity set 5 with the parameter named param1:
*setparameter param1 sets 5 LSD_DA1 0 0 0
   # Handle error
Version History
14.0
