*meshline_update_surface
Creates surfaces on closed meshline loops.
*meshline_update_surface flag reserved
HyperMesh Tcl Modify Command
This command creates surfaces on closed meshline loops.
flag
0 - Disable creating surfaces on closed meshline loops.
1 - Enable creating surfaces on closed meshline loops.
reserved
Reserved for future use. Must be set to 0.
To turn on creating surfaces for closed meshline loops:
*meshline_update_surface 1 0
   # Handle error
Version History
11.0
