*midmesh_extract
Extracts the midmesh of an input geometry.
*midmesh_extract entity_type mark_id string_array number_of_strings
HyperMesh Tcl Modify Command
longDescription
entity_type
The type of input geometry. Valid values are solids, surfs, comps and elems.
mark_id
The ID of the mark of input entities. Valid values are 1 and 2.
string_array
The ID of the string array that contains the additional optional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
Note: All parameters are case insensitive, and order insensitive. All parameters are optional, if not supplied, the mentioned defaults will be used.
Valid parameters and their syntax are:
CombineNonManifoldEdgesDistance=<value>
If two non-manifold/sharp edges are in proximity with another edge within the distance given for this argument, they will be merged together at the mid-location.
CombineNonManifoldEdgesFactor=<value>
Triggers the same option as CombineNonManifoldEdgesDistance, but the distance is expressed as a factor of MinimumSize.
A value of 1.0 means the CombineNonManifoldEdgesDistance is same as MinimumSize. A value of 0.5 means the CombineNonManifoldEdgesDistance is half of MinimumSize.
Default 0.5, range [0.0, 1.0].
DefeatureOpeningsFactor=<value>
Triggers the same option as DefeatureOpeningsWidth, but the distance is expressed as a factor of MinimumSize.
A value of 1.0 means DefeatureOpeningsWidth is same as MinimumSize. A value of 0.5 means the DefeatureOpeningsWidth is half of MinimumSize.
DefeatureOpeningsWidth=<value>
If a hole/opening is of lesser width than the given value, it will be closed.
DefeatureRibsWidth=<value>
If a rib's width is lesser than the given value, it will be removed.
DefeatureRibsWidthFactor=<value>
Triggers the same option as DefeatureRibsWidth, but the distance is expressed as a factor of MinimumSize.
A value of 1.0 means DefeatureRibsWidth is same as MinimumSize. A value of 0.5 means the DefeatureOpeningsWidth is half of MinimumSize.
DestinationComponent=<value>
Midmesh - All output mesh goes to Midmesh component or to the component whose name is specified in the DestinationComponentName argument. This is the default.
Midmesh.# - For each input geometry, the generated midmeshes are organized into a new Midmesh.# component. # denotes a unique incremental number.
Original - For each input geometry, the generated midmesh is organized back into the input components.
Original.# - For each input geometry, the generated midmeshes are organized into new Orignal.# components.
Current - All generated midmeshes go to the current component.
DestinationComponentName=<name>
The prefix to be used for the new shell element components created for the output mesh. Default is Midmesh
ExtractionSize=<value>
The size at which the midmesh is extracted. Default 2.0.
FlattenConnections=<value>
0 - The default Y shaped connections are retained (default)
1 - The output will be flattened at the connections. Y shaped connections are flattened to T shape. Stepped geometry (One side continuous surface, and opposite side steps) will be captured as continuous surface there by deviating from middle.
IgnoreFlatEdges=<value>
0 - No specific treatment done to remove flat bottom edges
1 - Flat bottom edges are not retained in the output
MinimumSize=<value>
The value used for defeaturing the topology based on the factors SupressProximityEdgesFactor, CombineNonManifoldEdgesFactor and DefeatureOpeningsFactor. It is recommended to set this value the same as the minimum allowable element length for your final target mesh. Default is ExtractionSize.
StepOffsetMode=<value>
This option allows finer control of how stepped geometry (one side continuous surface, and opposite side steps) is captured. This option is valid only when FlattenConnections=1. This option also deprecates FlattenConnections=2. For the sake of backwards compatibility, if FlattenConnections=2 is defined, StepOffsetMode is ignored. Valid values are:
Automatic - Steps of different thickness across a common base surface are automatically offset to a uniform distance from the base surface (default).
MidEverywhere - Each step will be placed in the middle.
MidThinnest - All steps that share a common base are moved to the middle of the thinnest step.
MidThickest - All steps that share a common base are moved to the middle of the thickest step. This might place parts of the midmesh outside the solid.
SuppressProximityEdgesDistance=<value>
If a manifold edge is in proximity with another edge within the distance given for this argument, it will be suppressed. Sharp edges are not considered for this operation.
SuppressProximityEdgesFactor=<value>
Triggers the same option as SuppressProximityEdgesDistance, but the distance is expressed as a factor of MinimumSize.
A value of 1.0 means the SuppressProximityEdgesDistance is same as MinimumSize. A value of 0.5 means the SuppressProximityEdgesDistance is half of MinimumSize.
TargetElementSize=<value>
This value is used for fine tuning certain internal computations to go well with the expectations according to the final target element size. It affects the suppression of flat edges, and edges in proximity. Default is ExtractionSize.
number_of_strings
Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
To extract the midmesh of all solids present in the model with element size as 2.0 with SuppressProximityEdgesFactor and CombineNonManifoldEdgesFactor as 0.5:
*createmark solids 1 all
*createstringarray 3 {ElementSize: 2.0} {SuppressProximityEdgesFactor: 0.5} {CombineNonManifoldEdgesFactor: 0.5}
*midmesh_extract solids 1 1 3
   # Handle error
Version History
2019
2020.1 - Added new options DefeatureRibsWidth, DefeatureRibsWidthFactor and StepOffsetMode. Deprecated FlattenConnections=2.
