*reviewclearbymark
Removes/clears entities from the review list based on a mark.
*reviewclearbymark entity_type mark_id
HyperMesh Tcl Modify Command
This command removes/clears entities from the review list based on a mark.
entity_type
The type of entity to remove from to the review list. Valid values are:
  • nodes
  • elems
  • points
  • lines
  • surfs
  • solids
  • connectors
  • loads
  • equations
  • systs
  • vectors
mark_id
The ID of the mark containing the entities. Valid values are 1 and 2.
To remove elements 1-100 from the review list:
*createmark elems 1 1-100
*reviewclearbymark elems 1
   # Handle error
