*flattenpartmodel
Converts entities that refer to parts to refer to root.
*flattenpartmodel reserved
HyperMesh Tcl Modify Command
For formula sets:
  • All clause – Updated to refer to root
  • Range clause – Range IDs of the clause will now refer to the begin/end range equivalent to the internal IDs
reserved
Reserved for future use. Must be set to 0.
Examples
To flatten the model:
*flattenpartmodel 0
   # Handle error
Version History
2020
