*mode
Sets the operations performed when a full-size plot is generated in a command file.
*mode type
HyperMesh Tcl Modify Command
type
Defines the mode or operations performed when a full-size plot is generated from a command file.
0 - This is the default action; HyperMeshwill wait for a key on the mouse to be struck before continuing.
1 - Generates a screen copy or a paper plot of the picture generated on the screen.
2 - Generates a file containing the contents of the screen buffer.
3 - Generates a PostScript paper copy of the currently displayed screen.
4 - Generates a PostScript file of the currently displayed screen.
5 - A value of five or greater causes HyperMesh to pause for that number of seconds before continuing.
To pause for 10 seconds after a full-size plot is performed, place the following command before the full-size plot request:
*mode(10)
None.
