*writecurrentqualitycriteria
Writes the current quality criteria to the specified file.
*writecurrentqualitycriteria file_name
HyperMesh Tcl Modify Command
The current quality criteria must be previously set. If the quality criteria is not set, the command writes the criteria from the quality index panel (interactive mode) or the default quality criteria adjusted to the current element size (batch mode).
file_name
The path to the destination criteria (a quoted string).
*writecurrentqualitycriteria "c:/demos/my_criteria.txt"
None.
Version History
2019.1 - Updated to also write 3D criteria.
