*alternatefejointcreate
Creates an FE joint element for use with the OptiStruct FE solution sequence.
*alternatefejointcreate type node1 node2 system1 system2
HyperMesh Tcl Modify Command
Creates an FE joint element for use with the OptiStruct FE solution sequence. The elements can correspond to JOINT, MBPTCV, MBCVCV, MBPTDCV or MBPTDSF cards.
For type 42, system1 and system2 must be specified as 0.
For type 43, require system1 to be specified and system2 may be specified as zero, And FE joint type 44 requires both system1 and system2 should be specified.
type
The type of FE joint element. Valid values are:
42 - Ball. system1 and system2 must be specified as 0.
43 - Revolute. system1 is mandatory, but system2 may be specified as 0.
44 - Universal. system1 and system2 must be specified.
node1
The ID of the first FE joint node.
node2
The ID of the second FE joint node.
system1
The ID of the first FE joint system.
system2
The ID of the second FE joint system.
To create a ball FE joint connecting nodes 10 and 25:
*alternatefejointcreate 42 10 25 0 0
   # Handle error
Version History
2017.1
