*removefilletbetweennodes
Removes the edge fillet between two nodes.
*removefilletbetweennodes nodes
HyperMesh Tcl Modify Command
nodes
The array of nodes from the node list. The first two nodes in the nodes array are used to remove fillets.
*createentity node x=-25.7203277 y=-212.155023 z=104.852423
*createentity node x=71.47504 y=-213.224288 z=96.3130724
*createlist nodes 1 1 2
*removefilletbetweennodes 1
None.
