*surfacemarkclipwithlines
Splits a group of surfaces with lines by projecting those lines perpendicularly onto the surfaces.
*surfacemarkclipwithlines surf_mark line_mark tolerance
HyperMesh Tcl Modify Command
surf_mark
The mark ID containing the surfaces.
line_mark
The mark ID containing the lines. The lines are temporarily combined into a single line, and therefore must be contiguous.
tolerance
The maximum distance the line may deviate from the surfaces and still be projected.
