*startnotehistorystate
Defines the start of a history state.
*startnotehistorystate name
HyperMesh Tcl Modify Command
Defines the start of a history state. Must be followed by a call to *endnotehistorystate with the same name value.
This is used to group a set of commands into a single undo/redo operation. All commands that appear within the start/end block must be supported for undo/redo.
name
The name of the history state. If the name contains spaces, it must be enclosed in curly braces or quotes.
To execute an element remesh operation on two selections of elements, but consider them as a single history operation:
*startnotehistorystate {Remesh two element selections}
*setedgedensitylinkwithaspectratio 0
*setoption element_order=1
*setusefeatures 3
*createmark elements 1 1-100
*defaultremeshelems 1 1 2 2 1 1 1 1 0 0 0 0 2 30
*createmark elements 1 1-1-200
*defaultremeshelems 1 2 2 2 1 1 1 1 0 0 0 0 2 30
*setusefeatures 0
*endnotehistorystate {Remesh two element selections}
   # Handle error
Version History
14.0
