*sphereclipradius
Set the radius for spherical clipping.
*sphereclipradius radius
HyperMesh Tcl Modify Command
radius
The radius the entities must be within for them to be visible when spherical clipping is enabled.
To enable spherical clipping at the origin with radius 10:
*sphereclipcenter(0,0,0)
*setsphereclip(1)
*sphereclipradius(10)
*sphereclipcenter() is required to view clipping.
*setsphereclip() is required to view clipping.
None.
