*makepreservednodes
Makes the selected nodes preserved.
*makepreservednodes mark_id
HyperMesh Tcl Modify Command
This command makes the selected nodes preserved.
mark_id
The ID of the mark containing the nodes to preserve. Valid values are 1 and 2.
To make nodes 1-4 as preserved:
*createmark nodes 1-4
*makepreservednodes 1
   # Handle error
Version History
13.0
