*reviewmaterialorientation_option
Reads and plots the first axis of the element (material) coordinate system for selected elements.
*reviewmaterialorientation_option entity_type mark_id only_orient normal_size color option
HyperMesh Tcl Modify Command
Reads and plots the first axis of the element (material) coordinate system for selected elements. When review is complete, the command *vectorsoff must be run.
entity_type
The type of entity to review. Valid values are elements and properties.
mark_id
The ID of the mark containing the entities. Valid values are 1 and 2.
only_orient
0 - The new x-element directions are shown as continuous gradient lines starting and ending on free edges.
1 - The new x-element directions are displayed as vectors starting from the element centroid.
normal_size
If only_orient=1, this defines the size of the displayed vectors.
color
The color of the vectors or lines. Valid values are 1-64.
option
Option for review customization. Valid values are:
1 - Abaqus rebar layer will be reviewed
To review the element (material) coordinate system of the displayed elements with blue vectors of size 3:
*createmark elems 1 displayed
*reviewsystem_option elems 1 1 3 7 1
*vectorsoff
   # Handle error
Version History
11.0.101
