*hf_setdiestampingdirection
Sets the stamping direction for the die module.
*hf_setdiestampingdirection x_coord y_coord z_coord reserved
HyperMesh Tcl Modify Command
This command sets the stamping direction for the die module.
x_coord
x-coordinate of the vector direction.
y_coord
y-coordinate of the vector direction.
z_coord
z-coordinate of the vector direction.
reserved
Reserved for future use. Must be set to 0.
To set the stamping direction in the die module to (1, 0, 0):
*hf_setdiestampingdirection 1.0 0.0 0.0 0
   # Handle error
Version History
11.0
