*ossmooth_savesurf
Exports the final design geometry from OptiStruct topology, topography and shape optimization results.
*ossmooth_savesurf mode filepath units output
HyperMesh Tcl Modify Command
mode
0 - Create .oss file only to be used in standalone version (do not execute OSSmooth)
1 - Do not load geom into HyperMesh
2 - Load geom into HyperMesh.
filepath
The full name and path of the OptiStruct .fem results file generated from the optimization.
units
Units used for IGES and STEP output. Valid values are:
  • 1 - inch
  • 2 - mm
  • 4 - foot
  • 6 - meter
  • 10 - cm
output
1 -Nastran
2 - IGES
3 - STL
4 - H3D
5 - STEP
6 - PARASOLID
7 - IGES (advanced)
To execute OSSmooth to save surfaces to STEP file C:/test/os1.step, using mm as units:
*ossmooth_savesurf 2 C:/test/os1.fem 2 5
   # Handle error
Version History
12.0
