*CE_ErrorSet
Assign a pre-defined error code to a connector.
*CE_ErrorSet id error_code
HyperMesh Tcl Modify Command
This command assigns a pre-defined error to a connector.
id
The ID of the connector.
error_code
The error code to assign to the connector. Valid values are:
  • 0 - CE_ERROR_UNDEFINED
  • 1 - CE_ERROR_PROJECTIONS_LACKING
  • 2 - CE_ERROR_LINKS_UNRESOLVED
  • 3 - CE_ERROR_INCOMPLETE_REALIZATION
  • 4 - CE_ERROR_INCOMPATIBLE_FECONFIG
  • 5 - CE_ERROR_NO_TEST_POINT
  • 11 - CE_ERROR_LINK_LACKING_THICKNESS
  • 51 - CE_ERROR_AREA_LACKING_MESH
  • 61 - CE_ERROR_BOLT_HOLE_NOT_FOUND
  • 62 - CE_ERROR_BOLT_HOLE_LACKING
  • 63 - CE_ERROR_OVERLAP_1D_ELEM
  • 71 - CE_ERROR_MESH_IMPRINT_INCOMPLETE
  • 72 - CE_ERROR_MESH_IMPRINT_ACROSS_FEATURE
  • 73 - CE_ERROR_MESH_IMPRINT_OVERLAP_WITH_ITSELF
  • 74 - CE_ERROR_MESH_IMPRINT_EXTREME_CASE
  • 75 - CE_ERROR_MESH_IMPRINT_MISSING_ELEMS
  • 76 - CE_ERROR_MESH_IMPRINT_OVERLAP_WITH_OTHER
  • 77 - CE_ERROR_LESS_HEXA_HEIGHT
  • 78 - CE_ERROR_CUSTOM
  • 79 - CE_ERROR_MESH_IMPRINT_FAILED
  • 80 - CE_ERROR_NSM_PROPERTY_NOT_POSSIBLE
Examples
To assign error code 80 to connector ID 10:
*CE_ErrorSet 10 80
   # Handle error
Version History
11.0.130
