*solidmap_solids_set_elemsize
Sets the per-edge element size within a multiple-solid solidmap command block.
*solidmap_solids_set_elemsize mark_id elem_size
HyperMesh Tcl Modify Command
This command is for setting the per edge elem size for solid map meshing. The size value specified is only a target value. Depending on solvability, the resulting mesh may take on a modified value. This command can only be called between a *solidmap_solids_begin and *solidmap_solids_end command pair.
mark_id
The ID of the mark containing the lines/edges to set the element size for. Valid values are 1 and 2.
elem_size
The value to set the elem size to for the selected lines/edges.
To mesh solids 32 and 41 with a default elem size of 2.0 except on edges 2 and 4 which should have an elem density of 10.0:
*createmark solids 1 32 41
*solidmap_solid_begin 1 0 2.0
   *createmark lines 1 2 4
   *solidmap_solids_set_elemsize 1 10.0
*solidmap_solid_end
None.
Version History
10.0
