*attributeupdatedoublearray2delementmark
Updates one element of an attribute of type 2D double array.
*attributeupdatedoublearray2delementmark entity type mark identifier solver status behavior row col value
HyperMesh Tcl Modify Command
entity type
The type of entity that owns the attribute.
mark
The number of the mark where the list of IDs reside.
identifier
The identifier of the attribute.
solver
The solver number of the attribute.
status
The status of the attribute.
behavior
The behavior of the attribute.
row
The row number the value to be changed resides in (first row is zero).
col
The column number the value to be changed resides in (first column is zero).
value
The new value of the 2D array element.
To update the item in a 2D array attribute to 5 (specifically row 3, column 2). The attributes are found on materials with IDs of 7 and 8. Do the following:
*createmark(materials, 1) 7 8
*attributeupdatedoublearray2delementmark(materials, 1, 1234, 1, 2, 0, 2, 1, 5)
