*spring
Creates a spring element between two nodes using an orientation vector.
*spring node_id1 node_id2 dof property_name vector_id
HyperMesh Tcl Modify Command
node_id1
The ID of the first node.
node_id2
The ID of the second node.
dof
The degree of freedom for the element.
property_name
The name of the property to assign to the element.
vector_id
The ID of the orientation vector assigned to the element.
To create a spring element between node 100 and node 101 with DOF 2, property springprop, and orientation vector ID 51:
*spring 100 101 2 "springprop" 51
   # Handle error
