*realizefieldloads
Realizes engineering loads into classical loads.
*realizefieldloads mark_id ?skip_delete?
HyperMesh Tcl Modify Command
mark_id
The ID of the mark of engineering loads to realize into classical loads. Valid values are 1 and 2.
skip_delete
0 - Delete all engineering loads after realization (default)
0 - Keep all engineering loads after realization
Examples
Realize all engineering force loads:
*createmark loads 1 "by config" 1
*realizefieldloads 1
Realize all engineering loads and skip deletion:
*createmark loads 1 all
*realizefieldloads 1 1
   # Handle error
Version History
2020
