*linessmoothtoangle
Smooths a line based on a give angle.
*linessmoothtoangle mark cosangle
HyperMesh Tcl Modify Command
mark
The ID of the mark containing the lines to smooth.
cosangle
The cosine of the angle used to determine if two joints on a line should be combined (smoothed). If the angle between two joints on a line is greater than the angle the two joints are combined and smoothed.
To smooth all joints on line 1 that have an angle greater than 90 degrees:
*createmark(lines,1) 1
*linessmoothtoangle(1,0)
None.
