*feinputpreserveincludefiles
Informs HyperMesh that the next call to *feinputwithdata2 should have the input translator recognize and preserve include file information, so that the model might be written out with the entities segregated into their respective files.
HyperMesh Tcl Modify Command
After the next call to *feinputwithdata2, HyperMesh will revert to the default behavior of reading and merging include files. For behavior other than the default behavior, this command must be called each time.
