*readfile
Reads a HyperMesh database into the current session and deletes any existing model.
*readfile filename
HyperMesh Tcl Modify Command
filename
The full path and filename of the database file.
To read the database named C:/mymodel.hm into the current session:
*readfile C:/mymodel.hm
   # Handle error
