*elementsaddelemsfixed
Marks the specified 1D plot elements as feature edges before using the command for remeshing by elements.
*elementsaddelemsfixed mark_id
HyperMesh Tcl Modify Command
This command changes the densities of selected surface edges and remeshes the adjacent surfaces, according to the specified mode. This is an automesh function.
mark_id
The mark ID containing 1D plot elements that should be considered to form feature edges in the subsequent element remesh operation.
Use of this command implies that it will be followed by a command that performs remeshing/meshing by elements:
*defaultremeshelems
*defaultmeshelems
*interactiveremeshelems
*interactivemeshelems
To remesh the displayed elements and keep lines formed by plot elements with IDs 1600-2220:
*createmark elems 1 "displayed"
*setusefeatures 1
*createmark elems 2 1600-2220
*elementsaddelemsfixed 2
*defaultremeshelems 1 3.0 2 2 0 1 1 1 0 0 0 0 0 30
   # Handle error
