*unmaskentitymark
Unmasks the entities on the specified mark.
*unmaskentitymark entity_type mark_id flag
HyperMesh Tcl Modify Command
This command unmasks the entities of entity_type that are on mark_id. Valid mark_ids are 1 and 2. Only entities in displayed collectors may be unmasked.
To unmask connectors and the realized FE, a flag of 1 must be passed. To unmask only connectors (excluding realized FE) and all other entity types, a flag of zero must be passed.
Currently supported entity_types for this command are:
  • connectors
  • points
  • lines
  • surfaces
  • solids
  • elements (both in components and groups)
  • ellipsoids
  • mbjoints
  • mbplanes
  • equations
  • loads
  • systems
  • vectors
  • tags
  • handles
  • domains
  • symmetries
  • morphconstraints
  • comps (connectors, points, lines, surfaces, solids, elements)
  • groups (master/slave elements)
  • loadcols (equations, loads)
  • multibodies (ellipsoids, mbjoints, mbplanes)
  • systcols (systems)
  • vectorcols (vectors)
Examples
To unmask all of the displayed connectors and the realized FE:
*createmark connectors 1 displayed
*unmaskentitymark connectors 1 1
To unmask all elements in components but not elements in groups:
*createmark comps 1 all
*createmark elems 1 "by comps on mark" 1
*unmaskentitymark elems 1 0
To unmask all entities in all components:
*unmaskentitymark comps 1 0
This command does not return any errors that can be handled.
Version History
9.0
