*writeh3dwithoptions
Writes an H3D file using various options to control the exported data.
*writeh3dwithoptions filename string_array number_of_strings
HyperMesh Tcl Modify Command
filename
Full name and path of the H3D file to save.
string_array
The ID of the string array that contains the additional output parameters. The string array is created using the *createstringarray command. This should always be set to 1.
Arguments can be provided in any order and must be space separated.
model=<value>
1 - Write FE data only (default)
2 - Write geometry (STL) data only
3 - Write both geometry (STL) and FE data
result=<value>
0 - Do not write results (default).
1 - For supported entities and result contours, this writes the displayed results to the H3D file. If no supported result contour is displayed, this option is ignored.
title=<value>
0 - Do not write HyperMesh titles as HyperView notes (default).
1 - Write HyperMesh titles as HyperView notes.
orient="n1x ny1 n1z n2x n2y n2z n3x n3y n3z"
The x, y, z coordinates of the 3 orientation nodes. The default is to not write orientation nodes.
overwrite=<value>
0 - Do not overwrite file if it exists (default)
1 - Overwrite file if it exists
number_of_strings
Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
To save an H3D as C:/test.h3d:
*writeh3dwithoptions C:/test.h3d 1 0
To save an H3D as C:/test.h3d with both geometry and FE data, along with titles:
*createstringarray 2 model=3 title=1
*writeh3dwithoptions C:/test.h3d 1 2
   # Handle error
Version History
14.0
