*attributeupdateentityidarray2delementmark
Updates one element of an attribute of type 2D entity ID array.
*attributeupdateentityidarray2delementmark entity type mark identifier solver status behavior target entity row col value
HyperMesh Tcl Modify Command
entity type
The entity type that owns the attribute.
mark
The number of the mark where the list of IDs resides.
identifier
The identifier of the attribute.
solver
The solver number of the attribute.
status
The status of the attribute.
behavior
The behavior of the attribute.
target entity
The type of entity to which the attribute refers.
row
The row number the value to be changed resides in (first row is zero).
col
The column number the value to be changed resides in (first column is zero).
value
The new value of the 2D array element.
Examples
This example assumes you want to update an element in a 2D entity ID array attribute to point to a loadcol with an ID of 5 (specifically located at row 3, column 2). The attributes are found on materials with ID's of 7 and 8. Do the following:
*createmark(materials, 1) 7 8
*attributeupdatedoublearray2delementmark(materials, 1, 1234, 1, 2, 0, loadcols, 2, 1, 5)
