*createelement
Creates an element from a node list.
*createelement config type list_id auto_order
HyperMesh Tcl Modify Command
config
The HyperMesh configuration of the element.
Type: integer
type
The solver type of the element.
Type: integer
list_id
The ID of the list containing the nodes. Valid values are 1 and 2.
auto_order
0 - Use the nodes as ordered in the list.
1 - Auto order the nodes in the list.
Examples
To create a quad4 element using nodes 14, 15, 16, and 17:
*createlist node 1 14 15 16 17
*createelement 104 1 1 1
   # Handle error
