*loadsupdatefixedvalue
Updates the fixed constraint value on SPC and SPCD constraint loads for OptiStruct.
*loadsupdatefixedvalue mark_id fixed_value
HyperMesh Tcl Modify Command
Updates the fixed constraint value on SPC and SPCD constraint loads forOptiStruct.
mark_id
The ID of the mark containing the SPC and SPCD constraints to update. Valid values are 1 and 2.
fixed_value
0 - Do not retain the deformed boundary resulting from a preceding nonlinear subcase
1 - Retain the deformed boundary resulting from a preceding nonlinear subcase
To update a fixed value for SPC load 4:
*createmark loads 1 4
*loadsupdatefixedvalue 1 1
   # Handle error
Version History
14.0.120
