*nodeplaceatxyz
Moves a node to a location on a surface and associates the node to the surface.
*nodeplaceatxyz node surface location
HyperMesh Tcl Modify Command
node
The ID of the node.
surface
The ID of the surface to which the node should be associated.
location
The location of the point on the surface where the node is to be moved.
To move node 115 to surface 1 at location (75,30,86):
*nodeplaceatxyz(115,1,75,30,86)
None.
