*xyplottwocurvemath
Performs a math function on two curves.
*xyplottwocurvemath function outputcurve xbased
HyperMesh Tcl Modify Command
function
The function to be performed.
outputcurve
The name of the output curve
xbased
1 - If the function should operate on the x coordinate.
0 - If the function should operate on the y coordinate.
None.
