*morphupdatedomainmethod
Updates method for selected 1D domains.
*morphupdatedomainmethod dtype dmark method
HyperMesh Tcl Modify Command
dtype
Domains
dmark
Domain mark number.
method
1 = Independent
2 = Slave
3 = Master
4=Cluster
*morphupdatedomainmethod (DOMAINS,1,3)
This command will update the method for assigning handles and dependencies for the selected 1D domains. Handles may be created or deleted during this operation as well as having the dependencies changed for handles on other domains.
None.
