*morphshapecreatelist
Creates a number of new shapes from the morph list.
*morphshapecreatelist name option color
HyperMesh Tcl Modify Command
This command creates a number of new shapes from the morph list.
name
The base name of the shape.
option
The shape's save options. Valid values are:
  • 0 - Save as handle and node perturbations.
  • 1 - Save as pure node perturbations.
color
The color of of the shapes. Valid values are 1 through 64.
To create shapes with the base name "shape" for all morphs on the morph list:
*morphshapecreatelist "shape" 1 33
   # Handle error
