*setmarktopologydisplay
Sets the topology visualization style for the marked geometric entities.
*setmarktopologydisplay entity_type mark_id vis_flag
HyperMesh Tcl Modify Command
This command sets the topology visualization style for the marked geometric entities.
entity_type
The type of entity to modify. Currently, only comps are supported.
mark_id
The ID of the mark containing the entities of entity_type. Valid values are 1 and 2.
vis_flag
  • 0 - Wireframe geometry
  • 1 - Shaded geometry and surface edges
  • 2 - Shaded geometry no surface edges
  • 3 - Geometry with surface lines
To set the visualization for the displayed components to shaded with surface edges:
*createmark comps 1 "displayed"
*setmarktopologydisplay comps 1 1
   # Handle error
Version History
9.0
