*settrimcuttingplanes
Turns the cutting plane trim option on/off.
*settrimcuttingplanes*settrimcuttingplanes*settrimcuttingplanes state
HyperMesh Tcl Modify Command
state
Specifies the trim plane option for all cutting planes. Valid values are:
0 - off
1 - on
To turn off the trim cutting plane option:
*settrimcuttingplanes 0
None.
