*midsurface_remove_display_plate_sides
Deletes the two components that contain copies of the model surfaces belonging to two sides of a given plate.
*midsurface_remove_display_plate_sides plate_number reserved1 reserved2
HyperMesh Tcl Modify Command
plate_number
Specifies the plate number for which the plate side information is to be deleted.
reserved1
Reserved for future use. Must be set to 0.
reserved2
To delete the plate information for the plate with plate number 127:
*midsurface_remove_display_plate_sides 127 0 0
   # Handle error
Version History
13.0
