*morphconstraintapply
Applies all morph constraints to the model.
HyperMesh Tcl Modify Command
This command applies the current constraints to the model. When constraints are created they are applied to the model so this command does not need to be called after creation of a morph constraint.
Note: Constraints are applied via a morph, which can be undone. Undoing such a morph does not reject the constraint.
If the model no longer obeys the constraints, for instance, if the constraints are turned off and the model is morphed, this command can be used to restore compliance.
None.
