*CE_DetailSetTriple
Sets a triple connector detail for a single connector.
*CE_DetailSetTriple connector_id detail_name triple_value1 triple_value2 triple_value3 reserved force_storage
HyperMesh Tcl Modify Command
connector_id
The ID of connector to update.
detail_name
The name of the standard triple detail, or user-defined triple detail, to update. Standard triple details include:
ce_dircords
The coordinates of the direction node.
ce_ijk
The vector definition used for realization.
triple_value1
The first triple value to update for the detail.
triple_value2
The second triple value to update for the detail.
triple_value3
The third triple value to update for the detail.
reserved
Reserved for future use. Must be set to 0.
force_storage
0 - Do not store user-defined detail.
1 - Store user-defined detail.
Examples
To set the projection vector to (0.0, 1.0, 0.0) for connector 1:
*CE_DetailSetTriple 1 ce_ijk 0.0 1.0 0.0 0 0
   # Handle error
