*plynormalsdisplay
Controls the display of 2D element ply normals.
*plynormalsdisplay ply_name mark_id size
HyperMesh Tcl Modify Command
ply_name
The name of the ply to display normals for.
mark_id
The ID of the mark containing the elements whose normals are to be displayed. Valid values are 1 and 2.
If empty, all plies in the specified ply are considered.
size
Specifies the size of the graphic normal vector. If set to zero, the vector is drawn at 10% of the screen size.
To turn on the display of normals for elements 1-10 in Ply1, at 10% screen size:
*createmark elems 1 1-10
*plynormalsdisplay Ply1 1 0
   # Handle error
Version History
13.0
